TAAT SL-1 tranny
Old Sep 6, 2012 | 06:33 AM
nicko-31's Avatar
Default TAAT SL-1 tranny
Does anyone know if it's possible to change shift points on a 2002 TAAT transmission ?? I am experiencing a tranny that shifts too soon and when it downshifts it bangs on down shift.I discussed earlier and I thought the issue was solved but I guess not. I've tested all 4 of the shift solenoids and all are within the range which I believe was 4.5 and not higher than 5 ohms.The car was neglected with fluid changes and I've since changed fluid twice.the last time I added trany treatment from LUCIS which did nothing but waste $13.00. Again Shift points is it possible to alter them. ?? Thanks
Old Sep 6, 2012 | 06:53 AM
There is no tune for S-Cars so there is no way to get into reprogram the engine or tranny.
Also check input shaft nut, it may need to be replaced.
Old Sep 6, 2012 | 10:13 AM
nicko-31's Avatar
Default Taat tranny
Aslo check input shaft nut, it may need to be replaced.
Can you ellobrate a little more on input shaft nut ?? Thanks
Old Sep 6, 2012 | 10:18 AM
nicko-31's Avatar
Input shaft nut replacement seems to be related to harsh reverse not early shifting and harsh downshift,from what I have been able to find.
Rubehayseed
Mar 19, 2014 04:50 PM
dizzymac
Apr 7, 2007 09:54 PM
tranceologist
Feb 22, 2007 06:27 PM
boogawooga
May 24, 2006 10:17 AM
HeatherP00
Nov 8, 2005 03:35 PM
