-   -   Sun roof won't work (https://www.saturnforum.com/forum/general-tech-help-13/sun-roof-wont-work-10071/)
RaceyRaider3 Jun 8, 2015 02:22 PM
Sun roof won't work
So I just bought a 2001 SC2 and it's overall a 7.5/10. All the electrics work except the sunroof. I checked the fuses and they are all good. I pulled the switch/vanity plate thinking I could easily access the switch but it appears not to be so.
Do these switches have a tendency to go bad or is the motor toast? There is no motor noise whatsoever when I try the switch.
Any thought will be helpful.
Thx. Doug
Rubehayseed Jun 8, 2015 07:07 PM
Are you sure you got the right fuse, Doug? Maybe it's one under the hood in that fuse box. I don't know, since I've never owned a sunroof equipped Saturn. IF you can reach the motor, try unplugging it and see if there's power to it with a test light. If you have power, it's probably the switch. No power, either a fuse or wiring issue.
RaceyRaider3 Jun 9, 2015 09:01 AM
Rubehaysee, is there more than one fuse box? I did check all the fuses in the engine compartment fuse box and they are all good (driving lights don't work either but I haven't pulled the bulbs yet). I know older GM vehicles had fuse boxes in the glove box area. I need to pick up a repair manual for it too.
Rubehayseed Jun 9, 2015 10:07 AM
Yes indeed! You have a fuse box on the passenger side of your console. Look at the console where your left knee would be if you're sitting in the passenger seat and you should see the little door. Pull the cover and it should be labeled. THAT should be where the fuse for the sunroof is, not under the hood.
derf Jun 9, 2015 11:33 PM
Rube meant left knee/PASSENGER seat.
RaceyRaider3 Jun 10, 2015 10:02 AM
Rube, I'll check for the fuse box tonight. Thanx.
RaceyRaider3 Jun 11, 2015 08:52 AM
Sure enough, there's the secondary fuse box and yep the sunroof fuse is missing, and for good reason. I replaced the fuse it and hit the switch... GRIND GRIND CLUNK CLUNK! It's toast.
Rubehayseed Jun 11, 2015 10:03 AM
Well, if it's making noise, it might not be the motor, but the drive gear. If it was mine, I'd just leave the fuse out and never use it. But it's not mine, so good luck with the repair if that's your plan.
derf Jun 11, 2015 11:31 AM
The sunroofs one the s series have always been problematic. I believe there are plastic pieces that are part of the drive system or guide rails that snap and render the sunroof inoperable. I believe Uncljohn has dealt with his. Can't remember if he got it working.
Search the site and the net for people in the same predicament. Not sure if parts still available from gm or aftermarket. If it seals on its own you're ahead of the game. Otherwise you need to get out the silicone.
Also, keep the drains clear. Search the site for info regarding where and how.
RaceyRaider3 Jun 11, 2015 01:51 PM
I'm sure it the drive system. not going to bother with it. Out comes the fuse...
