I have a broken wire for the rear window wiper on my 2000 saturn wagon. I need to remove the cover on the steering column. I can get the sides loose but not behind the steering wheel. I hope I don''t need to remove the steering wheel. Can anyone help me out here? Thanks in advance, B. A.
Did you remove the screws?
yep
I have found that when working on a 2000 vehicle, I have had to remove the ignition lock cylinderbefor I couldget the covers loose
All you have to do is remove the screws and the ring around the ignition cylinder. Then the two halves just seperate.
