SC2 Help Please
Old Jan 5, 2011 | 10:25 AM
linckeil's Avatar
Default SC2 Help Please
hi guys - new member, but have been visiting the forum recently.
i have a 1997 SC2 with 1.9 DOHC. bought it 2 years ago with 160k, now has 185k and has performed great up until now.
recently in the cold weather (i'm in CT) it has been hard starting. after cranking for 2-3 minutes it would start and run perfectly, and then restart just fine so long is it didn't sit in below freezing temperatures for over 8 hours. 2 weeks ago i replaced the ECTS, ECTS connector, and installed a new fuel filter. car worked great for about a week (outside temps were warmer), but now that the cold has returned, car is now not starting at all, no matter how long i crank for.
so i did some checks. fuel pump primes up when turning on the ignition. no spark off any of the 4 wires. remove the wires from the coil packs, and no spark jumps between the terminals. i replaced the CPS a year ago for good measure, but maybe it went bad? what else should i be checking? how do i check the coils? its definetly an ignition problem. what about the PCM? and what fuses/realys i should be looking at? all the big green 30amp fuses in the fuse box under the hood are good.
what should i do? any easy/inexpenive stuff i should be checking first? i have a multimeter i could use to check resistances.
any help is appreciated. this is my daily driver and if i keep driving my truck to work the fuel prices will have me in the poor house soon!!!!
Old Jan 5, 2011 | 11:14 AM
john doe's Avatar
i would spray some starting fluid into the throttlebody and see if it attempts to start .if you dont get any response from that its a sure bet that theres no spark.
Old Jan 5, 2011 | 12:18 PM
linckeil's Avatar
done that. has no impact. definetly a spark issue. where do i begin?
Old Jan 5, 2011 | 01:44 PM
Well, I'd try this ....
On a cool day that the car starts the first time, I'd spray the CPS with a can of freeze spray (available at RadioShack or equal), and get the CPS unit as cold as I could - then try to start again. It might show up a temperature sensitive module. Of course, you could just replace the CPS first, and see if that fixes your problem .....
Old Jan 5, 2011 | 02:14 PM
linckeil's Avatar
i don't think its gonna start up for me again. it always started in the past after 2-3 minutes of cranking, but i've tried it on several occasions over the past couple of days (without completely draining the battery) and its not starting.
when i get it home in my garage, i'll heat the garage up with my space heater and try to start it. i doubt it will, i think its just a coincidence now that it got cold and won't start.
do you know what kind of resistence i should see on the cps? i can put my multimeter on it. any test i could do on the coil packs? relays i should check? test on the pcm?
thanks for your reply.
Old Jan 5, 2011 | 09:44 PM
hoseppi's Avatar
You should be getting about 800 ohms across the CPS terminals.
Old Jan 9, 2011 | 05:42 PM
linckeil's Avatar
cps was good. was a bad icm. $20 for the icm and both coils at the junkyard and i'm up and running.
pauledgar
Sep 9, 2012 08:25 PM
jeff2001sc2
Jul 8, 2009 04:18 PM
23ska
Apr 2, 2007 05:13 PM
mygsrtegn757
Nov 15, 2006 09:31 PM
