Saturn SC1 2002 - Installation of Power Windows?
Would it be a hard DIY?
- I'm fairly proficient with electrical circuits but adding a circuit into a vehicle is different then a computer though I'd say. Lol.
Same thing with FOGLIGHTS!!!
I have them on my bumper but they're just for looks!
Easy to add?
Easy to add?
do you mean installing Power Windows in a non-power window car?
Fog lights have been done many times. There is a "double switch + dimmer"---one with Traction Control, one without. Strangely, per Rock Auto, both have the Fog light switch on them, so SHOULD be able to trace the wires from the wiring harness to....probably the Fog Relay in the Underhood Junction Box (UHJB). You would then need to figure out which terminals on the relay (which you'd need to buy) correspond to the power to the fog lamps, and wire them up. Adding in the FOG fuse (not sure if it is separate) should complete the circuit.
ALL this depends on whether the harness has wires to control the FOG LAMP relay in that multifunction thing I mentioned earlier. Without it, you'd have to pull the UHJB and wire the switch leads too, then do a homemade switch install somewhere on the dash -- or possibly just add pins to the connector and use the existing switch
Another highly theoretical post with no solid answer. Could even be correct.
Sorry.
Sorry.
Banger -- please create a signature like ours
First Name/Location (State)
Year Model Engine Tranny Mileage.
It's on the left side in the user control panel.
Congrats on post #10. Welcome to the Saturnforum family.
You have no idea what you've gotten yourself into....
19bonestock88
Apr 2, 2013 02:31 PM
