Powerless 96 SL1 SOHC
Old Jan 13, 2007 | 10:43 PM
pacbrown's Avatar
Need some guidane desperately. A couple of days ago my son is driving our sl1 when the battery light came on the car immediately lost pwer. max speed was about 5 MPH. I tried replacing the battery, no go. Checked both cables and no problems there. When the key is turned on there is no power going to anything. When we first tried with the new battery there was a single click. Nothing since. What is my next course of action? Any likely candidates for the cause?
Thanks,
Old Jan 14, 2007 | 12:31 AM
Any fuses blown (instrument panel and underhood junction box)?
Any molten wiring/insulation/residual smell of burned plastic?
Old Jan 14, 2007 | 01:01 AM
pacbrown's Avatar
None that I could find. All fuses to include maxifuses look good. I am really stumped.
Old Jan 14, 2007 | 10:52 AM
Was the battery leaking............if so remove the battery and battery tray. If the wiring harness is wet or white from acid?, you'll need to replace that harness. Also check your possitive battery cable. Is it rotting away from acid. Is it swollen from acid. Peel back a bit of casing near the terminal end and look for corrosion. Replace if any is found.
Old Jan 14, 2007 | 01:25 PM
+1 ; "it's not a complete circuit anymore" is the most likely answer. Are you sure both the + battery lead and - (the ground) lead are electrically and physically sound?
Old Jan 14, 2007 | 03:41 PM
pacbrown's Avatar
Checked both with an ohm meter and they are good. I am going to check the wiring harness and clean the connectors on the leads and let you know what happens.
calvintanner
Sep 26, 2010 05:23 PM
jacobshain
Aug 13, 2010 02:47 AM
LinkFarms92
Mar 17, 2010 11:42 AM
Bing
Feb 3, 2009 07:49 PM
sl1fan
Jul 10, 2008 01:43 PM
