power lock security breach?
Old Mar 30, 2015 | 04:14 PM
moparren's Avatar
Default power lock security breach?
Hello
We have an 06 Vue that is presenting me with a problem. We have come out to an unlocked car in the morning about 8 times in the last month. It has gotten to the point where both my wife and I go out to witness the other locking the car. This is only happening at home, it has yet to happen at work.
To my thinking one of two things is going on - the car has a random fault and is unlocking itself, or someone in the area is broadcasting a signal that is unlocking the car. (seems more likely as it is not happening at work)
If it is a fault, where should I start looking?
Is there a way to chance the code/frequency to lock out the wrong signal?
Thanks
Dave
Forgot to add this is a base model Vue. 2.2 motor with 5 speed
Old Mar 30, 2015 | 07:01 PM
You need to reset with a TECH II, and both remotes must be present.
Any low battery conditions remote or car might cause a problem. Reprogram the remotes and go from there.
Old Mar 31, 2015 | 04:38 PM
moparren's Avatar
Thanks! Any recommendations on where to get tech II? The shop I go to just quoted around $150 to plug in and do the programming. I have an OBD2 scanner but I'm sure it lacks the capability to do anything other than engine codes.
Old Apr 1, 2015 | 05:02 AM
You may be able to pick up a used one for $1000.00 bucks with the candi module via ebay. Start going to a new shop......Stop at your nearest Chevy dealer price to reprogram remotes will be far less, and can be done right on the service drive in a matter of minutes.
Old Apr 2, 2015 | 08:15 PM
moparren's Avatar
My nearest Chevy dealer would most likely tell me it's a rare part and they would have to keep the car a week while they do a special order...
I'll do some shopping around.
Old Apr 2, 2015 | 08:27 PM
Okay then.
Old Apr 6, 2015 | 02:19 AM
Is it possible that someone is leaving their key fob jammed up in a pants pocket and something else in the pocket is leaning on the unlock button.
It has happened to me. With the fob in my pocket. While driving. With the panic button.
It CAN happen.
My vote is that it's your husband's pocket stuff.
Or, if you are leaving your keys in a common area in the house and you have young children, there's a little mischief at work..
Old Apr 6, 2015 | 08:06 AM
Ehhh, derf, the OP is a dude named Dave. Wake up!
Old Apr 6, 2015 | 10:27 AM
Sorry, dude named Dave. My bad.
Still guessing it's a pocket jam up of something against the key. If it was someone else's transmitter --which is possible-- I would think it would happen more frequently.
To test that theory, just approach your two nearest neighbors on your side of the street and those across the street and ask them to cycle through the buttons on their fobbs for all their cars to see if there is indeed a commonality.
I've only had this happen once in 18 years in a parking lot -- my door lock/unlock transmitter signal matched the panic alarm enable/disable signal for some other dude's ride.
Oh well.
________________
Dave,
Can you please config a signature that looks like ours? Keeps me from making such erroneous claims + we all know who you are and what you drive w/o having to scroll up 33 posts every time the thread gets updated.
wes0778
Jun 18, 2011 06:29 PM
alex_0227
Jul 18, 2009 07:36 AM
coupeguy08
Nov 17, 2008 11:31 AM
mflury
Aug 24, 2008 02:47 PM
lukeswoota
Nov 3, 2006 08:17 PM
