P0410. Can I look up a fix for this code?
Old Jan 21, 2009 | 05:42 PM
salesman11's Avatar
Hello,
I have a 2000 SL2. I need a smog check but I''m getting code P0410 & U1301.
(I see that P0410 is secondary air injection system, but what is that, and whats the fix?) Same with u1301.
Thank you, Ron
Old Jan 24, 2009 | 11:51 PM
original007's Avatar
u1301 is a communication code dont be too worried about that yet if ever.Now the 410 when you first start the car the air pump will run for a short time to help warm the catalytic converter,any way the causes can vary from the pump to the solenoid to the valve or even the ports in the exhaust manifold or head being clogged with carbon not allowing the air into the exhaust system. The car looks at the o2 sensor when the pump is commanded on,it should be very lean since it is supposed to be pumping air into the exhaust. If it does not see this the p0410 is set, up to you to determine why.If you remove the chrome tube between the valve and exhaust manifold then start the vehicle you should hear the pump running and feel air coming out, if this is the case the ports are clogged,if not you have some diagnosing to do.
Old Jan 25, 2009 | 10:45 AM
Low Saturn's Avatar
Originally Posted by original007
...or even the ports in the exhaust manifold or head being clogged with carbon not allowing the air into the exhaust system.
This is most likely the problem.
Old Jan 25, 2009 | 10:58 AM
salesman11's Avatar
Thanks for the replys.
I did pull a hose, just after start up, when it was cold, and no fan.
I did read, on one site, that the valve is the probalem 90% of the time, so for about $100 I can get a new valve and the selinoid.
(I wonder if I can touch it to the battery real quick and see if it goes?)
Also it runs very ruff, suspect this may not help the ruffness. And I don''t see a thing where I can adjust the idle with a laptop, but I do see a gas saver/hosepower adapter on e-bay it has %100 positives and is only $29 I am thinking about trying next.
goaliemo
Aug 2, 2015 12:22 AM
sc1
Jan 22, 2013 01:59 PM
madmatt9471
Dec 28, 2008 07:59 PM
Rowe
Dec 31, 2007 03:18 PM
QK97SC2
Mar 12, 2006 01:28 AM
