Oxygen sensors and no start
Old Jul 3, 2011 | 01:48 PM
trike1946's Avatar
Default Oxygen sensors and no start
This is a continuation of my list of problems on my 99. The others all got fixed, with the last being the oxygen sensors. Now it won't start. I changed the one under the hood first then moved the car to a better place to jack it up. So I know nothing was wrong after the first one. I jacked the car up from the side pretty high since I am not as thin as I used to be. I changes the sensor and got the old plug apart with a little difficulty because of the lack of room. Put the new plug together and let the jack down. I wanted to see if I triggered any codes so I went to start it and nothing. Radio and lights all work but it will not turn over. Is there a fuel cut off somewhere that might have tripped when I jacked it up? Or is there something else I should look for? Thanks for any help.
On edit - I let it sit for a while and went back to it and it started. I am not sure why but it is running. I didn't do anything to it. I was looking for the book. When I found it in my truck I came back and it worked. I think this happened once before. Does jacking it up do anything to it to keep it from starting for a while?
Old Jul 3, 2011 | 11:10 PM
start with a battery cable connection/condition check, then a battery check itself.
otherwise possibly a starter on the way out.
But start simple
Old Jul 14, 2011 | 07:42 PM
trike1946's Avatar
So far so good. Everything works and starts every time. Maybe it is back to normal and I can go back to my career of fixing my truck.
Old Jul 14, 2011 | 10:52 PM
I'm not entirely sure, but I think there is a disable circuit if the car goes into a "rollover" condition (supposed to cut down on vehicle crash/fires), but you would have had to have the key turned on when you jacked the side of the car to trigger it.
Used to be a pushbutton reset when they first appeared, perhaps now, they reset automatically after a certain period of time (or maybe if you remove the key, then reinsert).
Lemmie do some more research on this, and I'll get back to you .....
Old Jul 20, 2011 | 01:04 AM
The disable circuit I was under the impression turned off the fuel pump if the car tried to turn turtle or had a violent impact. I never have had a problem with one so can't say anything intelegent. I have however jacked my Saturn up high enough to get both wheels on the same side off of the ground using a hydraulic floor jack. (The frame on them is really stiff) I never caused a problem doing it. I would suspect a possible electrical problem caused by corrosion with a battery connection at the battery + or -, at a ground connection to the chassi or the starter solenoid. Thus sort of agreeing with Derf.
Old Jul 20, 2011 | 05:23 AM
trike1946's Avatar
Thanks for the replies. I think this also happened when I changed the starter. But it corrected itself. I had it jacked up high enough to get ramps under the wheels for safety. I am not only a bit larger than I should be but I have a bad case of claustrophobia, so I like a lot of room.
Old Jul 20, 2011 | 12:52 PM
indeed jacking should not have caused you a problem in and of itself
scottybk
Mar 14, 2014 10:54 AM
dbhost
Feb 2, 2012 06:11 PM
g14it
Aug 10, 2011 08:08 AM
Mpd105
Mar 8, 2011 03:59 PM
josaL200
Dec 4, 2008 08:16 PM
