Online Saturn Manuals
Saturn Workshop Manuals
Many models of Saturns covered.
They vary in detail and content but should be helpful to our Saturn community.
I cannot find the repair manual anywhere!!! I got a year subscription to alldatadiy and then repair surge, but they're not what I need. I found a service manual for my wife's pathfinder at "Download-Service Manual.com" but when I search for Saturn, it show two entries for the SL2 (2002) and then redirects to Tradebit - which didn't have what I was looking for....smh.
I am really hoping that I don't have to spend the $300+ from gm to get the entire thing, but it's not looking good. I haven't bothered with Haynes/Chilton since I've seen enough negative information on the forums that I think it would be a waste of $$$.
Does anyone have any solutions??
Hi there Flanker7, I do have a link where you can download a PDF file for S-Series Factory OEM Repair Manuals, for a mere $13.00. They also accept Pay-Pal. It covers 97-02, Saturn SL1, "SL2", SW1, SW2, SC1 and SC2. Covers all repairs available for those models, here is examples of what's included but not limited to:
1.9 L L24 I4(Gasoline)
1.9 L LL0 I4(Gasoline)
4-speed Saturn MP6 automatic
4-speed Saturn MP7 automatic
5-speed Saturn MP2 manual
5-speed Saturn MP3 manual
Interior and exterior trims
Hvac, Horn, Wiper and Washer system
Onstar system
Wiring
Front and rear suspension
Brakes, hydrolic brakes
body panel
doors, immobilizer, ABS, airbags
Plus a lot more...
Derf may know where you can find this for free, sorry I do not, but the information you seek is out there, usually for a price...
Saturn SC PDF Manuals online Download Links at Saturn Manuals
Saturn S-Series 1997 to 2002 Service Workshop Repair manual
Onstar system
Wiring
body panel
Plus a lot more...
You are welcome Flanker7! SL2 is Dual overhead cams, so you have the MP3. The MP2 is designed for the single overhead cam. The only difference between these two manual transmissions are the gear ratios.
There is a discussion on swaping 5th gear from a MP3 into a MP2, and results in setting codes, pros and cons about the swap and why. Derf commented on that post as well when someone commented on changing the PCM. A DOHC PCM will not work with a SOHC engine without setting a ton of codes...if it even works at all!
http://www.saturnspot.com/showthread.php?t=31561
Here are the ratios for both, all years and models. Remember...SOHC=MP2, DOHC=MP3
https://en.wikipedia.org/wiki/Saturn_MP_transmission
