oil usage
Old Nov 18, 2005 | 06:01 PM
BOBWAN's Avatar
I have a 95 sl2 and have been told and read a report online that said
the 95 burns oil because saturn designed something wrong with the
engine but wont admit they did. Ive found that synthetic oil and
synthetic lucas oil treatment works very well
Old Nov 20, 2005 | 12:55 PM
stevestar99's Avatar
Saturns are oil burners, use a heaver weight oil. 10w-40 and some kind of additive.
Old Nov 27, 2005 | 03:20 PM
dannyy72's Avatar
I have a 92 SL2 and it does the same thing. I did what stevestar99 suggested. It did lower the consumption a little bit but not by much. Now I just come to term with it.
Old Jul 27, 2006 | 02:41 AM
j-pizzle's Avatar
Originally Posted by starless127
Short of installing a gas chromatograph on my tailpipe, I assume that the oil is being combusted and expelled out as CO2 or some sort of a volitile ketone or ester (there's a sweet smelling odor coming from my exhaust). In my experience, and from everything that I've read about this on Deja.com, Saturn owners experience no noticible dripping.
So what causes this and what can be done to fix it ?Because this totally describes my problem.-thanks
1999 sl2 dohcEdited by: j-pizzle
Old Jul 27, 2006 | 07:09 AM
97sc2's Avatar
I have a 97sc2 and have never had that problem with the oil. i do ride the car a little hard and that still makes no difference. Get it checked out by a mechanic it could be that you either have a leak somewere or that your engine is not properly mixing everything.
Old Nov 17, 2006 | 01:41 PM
scott1501's Avatar
I have the same problem with my '95 sl2, but I noticed the other day when I was changing my spark plugs that there was oil covering 2 of the plugs inside the head. I was told that I have to take of the head, clean and put some kind of new seal on. I'mdont know cars to well, just lurning as things break on my Saturn.[img]smileys/smiley5.gif[/img]
Old Nov 17, 2006 | 03:45 PM
paulorlo's Avatar
I believe that with the high temperatures found in the catalytic converter- oil burning is not as noticeable at the tail pipe. With that said you still should see blue smoke in your rear view mirror when you excellerate from a standing position especially with the motor not fully warmed up.
