oil in spark plug tube
Old May 21, 2006 | 03:33 PM
Turbochump's Avatar
[img]smileys/smiley6.gif[/img] Oh man! Just checking to find out why engine is missing a little. Pulled the first plug wire and there was 2 inches of oil in the tube! The other three tubes were clean, so I'm running on 3 cylinders. I am assuming a cracked or broken ring. Anybody have similar experience to this? How difficult/expensive to fix?
Old May 22, 2006 | 12:53 AM
Turbochump's Avatar
[img]smileys/smiley3.gif[/img] Gave it some more thought. Oil past a cracked ring would be burned up or at least pushed out.
Old May 22, 2006 | 02:34 AM
Sounds like valve/cam cover gasket issue. Each cyl has an o-ring like seal around the spark plug well. Probably all it is.
Replace wires and plugs first. Once you confirm all cyls are good, go after the gasket.
Throw in a compression test to set your mind at ease.
Hope this helps
Derf
Old May 23, 2006 | 01:15 AM
The cam cover is leaking................nothing more. Replace it. Do not replace the wires and plugs first. All thats going to do is soak the new plug and wire in oil as the cam cover keeps leaking.Edited by: sw2cam
Old May 23, 2006 | 09:46 AM
Indeed, you do not want to wreck a brand new set of wires. Obviously not thinking clearly.......
My bad.
Thanks for keeping me honest, sw2cam.....
Derf
Old May 23, 2006 | 10:39 AM
Turbochump's Avatar
Thanks guys...I'll be there Thursday to work on it again and will do.[img]smileys/smiley1.gif[/img]
Old Jun 7, 2006 | 02:35 PM
Turbo.....................how did everything go? All is well we hope.
Old Jun 7, 2006 | 04:25 PM
Turbochump's Avatar
I replaced plugs and tightened them down appropriately and tightened the valve cover; also put in a bottle of oil treatment to swell various seals. So far, so good. I'm checking it weekly when I visit. Thanks for the advice, guys.
Old Jun 11, 2006 | 02:54 PM
Sooner or later that cam cover gasket will need replacing. Might get yourself one and be ready for it.
Old Jun 18, 2006 | 11:19 PM
Turbochump's Avatar
I thought as much. Probably a good idea. Will do. Thanks.
