OBD1 key codes
sorry to bother but i been searchin for the key codes all over a.k.a. key dance .... i want to figure out why my CEL light is on ... idk how to do it on saturns either ... i only know how to do OBD2 Dodge Intrepids lol... so if someone could get me the instrucions and the codes that would be greatly appreciaated..
thanks, wink |
I thought what...............when I hear key codes I think this.
http://en.wikipedia.org/wiki/Key_code |
ok i did the jumper and im only getting 12 ... but yet my CEL light still remains on ... whats the issue??
Possibly a loose gas cap. Make sure it's on properly, and doesn't leak. Then, drive it for a couple of driving cycles, and the light should go out.
oh its on there tight lol ... i always make sure of that because i got gas the other day and it still remains on
You gotta twist it until it clicks.
CEL issues are a bit misleading, because even though they do not "set" a trouble code in memory, they do take a bit of time to clear - such as a problem with a loose gas cap. Even knowing where the problem was, and correcting it immediately, it took nearly two weeks for the light to clear on my L200 ...
ill just unhook battery lol
cycle key from off to on (not run) 50 times in succession
