No Start SW2
Old Mar 29, 2012 | 01:59 AM
slotmanmike's Avatar
Unhappy No Start SW2
Hi: I have a 2000 Saturn SW2 with 138K on it. Today I have a NO START situation. Turn the key and all I hear is the fuel pump relay click. NO other sounds besides the usual dinging when you first turn the key. All the dash lights work and DO NOT dim when the key is turned. Tried locking & unlocking the wheel, starting in neutral, rocking the car backwards all with no results. Fiddled around for about 30 minutes. Any ideas?? Thanks! Mike
Old Mar 29, 2012 | 10:34 AM
First: Make sure the battery cables are tight.
Second: Make sure the positive battery cable is not corroded on the inside.
Old Mar 31, 2012 | 09:34 AM
trike1946's Avatar
Welcome to the Saturn Forum. Have you made any changes to the car recently? Do you have any way to check for trouble codes? How old is the battery? Starter? All the fuses good? Connections at the starter tight and clean?
x2 on what sw2cam said.
Old Apr 6, 2012 | 12:26 PM
SlotManMike --
Did you get your problem resolved ??
jcoll72305
Jan 24, 2013 09:45 AM
bomont
Jan 1, 2011 08:32 PM
ryankhemraj
Nov 1, 2010 10:26 PM
rbwck
May 16, 2010 10:59 PM
