newbie help
hello and thanks for helping. i have a 1995 saturn sl2 5 speed.146,000 miles. recently i had to jump start my car but crossed the jumpers wrong just briefly. every sense then the radio don't work and the rear window defroster don't work. I went out today and got used radio from junk yard. pluged it in and all i got was static checked all connections even antenna.replaced the rear window defroster . i touch it lights but don't stay on i also checked all fues. thanks
defroster --- prob the defroster/defogger relay in the IPJB
radio -- must have been pulled from a 95-99 to be compatible. If it was, do a continuity check betw the antenna connector and the antenna tip.
Top right of most pages you'll see your username. Next to it a drop down, click it. Add your first name, location, and car to your "signature".
Stop in the new member sub-forum and introduce yourself to the gang. You really want to use this site for help and info......get your post count up to ten. If not your account will be shut down like thousands of others.
Salvatore Giordano
Oct 1, 2010 07:59 PM
