low compression, oil in coolant?
Old Aug 18, 2005 | 03:20 PM
bmxgoof's Avatar
1996 SC2 (DOHC) it had low compression, almost a gallon of coolant in the crankcase, and some oil in the coolant. I disassembled the engine assuming it was a head gasket but there didn't appear to be anything wrong with it. What I need to know is, is it common for a saturn DOHC to crack somewhere? Hopefully I can find out soon so I can take necessary action. Thanks [img]smileys/smiley2.gif[/img]
Old Aug 18, 2005 | 08:27 PM
Patrick's Avatar
Administrator
i believe that if you look at the head under a black light, it may show the crack, otherwise, i would check with a machine shop, or any performance shop
Old Oct 17, 2005 | 05:52 PM
ottjoe88's Avatar
the head is definently cracked.
Old Oct 18, 2005 | 03:35 PM
ottjoe88's Avatar
oil in the coolant, but no coolant in the oil is typical for saturns with a cracked head, most of the time they will even pass california smog
Old Jul 27, 2006 | 01:31 AM
bmxgoof's Avatar
Just to follow up, I've got the car running finally.
The engine was overheated and the head badly warped, too much to be machined.
I got a used head off ebay, engine good as new!
Old Jul 27, 2006 | 02:02 AM
Congrats....................
rabobanks
Jul 7, 2008 09:10 AM
mgebo52
May 3, 2008 10:31 AM
bigoals
Feb 3, 2008 06:20 PM
fredo
May 30, 2006 09:46 PM
Beanie
Feb 9, 2006 04:45 PM
