Interment turn signals
Old Oct 18, 2008 | 04:57 PM
d2jhenson's Avatar
In my 2002 L100, the turn signals are interment. Where is the flasher and how do I get to it? The hazard side seems to work O.K.
Old Oct 18, 2008 | 05:07 PM
Actually, the flasher unit itself controls all of the lights through a single set of contacts. If it works OK when you switch the hazard lights on, it is not the culprit.
I suspect that the switch on the steering column is probably to blame; either that, or loose/defective wiring in the circuit from the steering column to the flasher unit (which is located on the instrument panel fuse block).
ford88mustang
Nov 15, 2009 07:17 AM
Seth K
Nov 10, 2009 09:27 PM
sts9
Nov 5, 2007 10:00 AM
4mula1
Apr 11, 2006 07:33 PM
4mula1
Feb 17, 2006 09:35 PM
