Ignition SignalWiper loose
Old Jan 24, 2013 | 08:30 AM
blu02sl's Avatar
Default Ignition SignalWiper loose
I have read the many posts regarding loose ignition and turn signal/wiper switch on column being the two screws that have to be removed with a chisel. In my case it is the shaft or tube that is moving. The ignition assembly is tight to the shaft or tube. When I hold that shaft or tube it is stationary. What is actually loose causing this problem? Thanks
Old Jan 24, 2013 | 09:34 AM
don't know the answer
please stop double posting
Old Jan 24, 2013 | 03:24 PM
I don't know whats loose in you car. I can't take it apart and see. Maybe thats something you should do or have someone that knows what they are doing look at it for you.
70.155.117.97
Country:United States
State/Region:Georgia
City:Lawrenceville
Latitude: 33.9562 (33° 57′ 22.32″ N)
Longitude:-83.988 (83° 59′ 16.80″ W)
Area Code:770
Old Jan 24, 2013 | 09:42 PM
blu02sl's Avatar
Sorry for the double post. Just registered and I find it confusing. Where are the fasteners located which keep the steering tube stationary?
Old Jan 24, 2013 | 10:07 PM
Check with your local Saturn-friendly GM dealership. There may be a safety bulletin out on the steering that would apply to your vehicle.
Squiz
Oct 20, 2013 06:02 PM
redvue
Dec 2, 2011 11:19 AM
john doe
Jan 2, 2011 01:24 PM
polymer52
Saturn L300
May 17, 2009 09:01 AM
mkeymaster2@aol.com
May 6, 2009 02:28 PM
