Do you get the same cam code error after failure? do you get any other codes after failure, like misfire codes?
From where are you sourcing the coils for the problem car? From where did you source the last pair of coils from the "no issues" car? They are both second gen sl cars so i wouldn't expect anything different ignitionwise If I understand correctly from your posts, you replaced both the ignition module AND the coils at the same time. That's two variables at once. So you don't yet know which part is acting up and which is not, or if it's both--or if it is neither Then there's the issue of plugs. You said you have been running v power NGKs which are copper which is good. Have you tried the stock NGK #BKR4ESA11? The ignition systems on these cars can be finicky. Also, are the wires within normal spec for a saturn S car (below 12K Ohms)? I'm not trying to insult your intelligence about these saturn engines but often times it's the simple stuff we forget to consider that is contributing to what seems to be a complex problem ECMs can be replaced but they need to be "matched" to your car and finding one that is the correct match can be difficult. I don't think that would help since the fuel maps and ignition timing is likely identical....etc --------- My reccommendations: Try a pair of the stock NGKs above, $1.50 ea fr Rockauto check those wires. If still misbehaving, I would say the next step is to further reduce the variables. Ignition module spark test Swap both suspect ignition modules under a pair of known good coils and see if they are good or if they are the problem. You can perform the ignition module spark test ---remove plug wires at coil towers ---crank engine a few rotations---should produce strong spark between coil tower posts ---have a friend note presence/absence and strength of spark. If spark on one coil is weak, swap the two coil positions and retry. If the weak spark follows the coil, the coil is bad. If it doesn't the ignition module is bad If you get two strong sparks then the ign module and both coil packs are good, provided the coils meet the resistance spec below. The resistance across each coil pack should be 7-10 K Ohms Likewise do the same with a known good ignition module and swap in your suspect pairs of coils to see if they are the issue. I am known for my longwindedness -- though uncljohn has me beat by a mile:D. If you don't believe that, search for posts by him......:) but we still love him and he is full of juicy mechanical knowledge you can only get by keeping your hands greasy for 40+ years (Rube's another old timer with greasy hands) Hope this helps. Trying my best. As to why the 98 doesn't act up under the same circumstances? Only the Shadow knows...... |
