Idle problem
Old Jan 24, 2008 | 11:07 AM
jtslbarnes's Avatar
I have a 2000 SL1. When I start the car it initially idles at around 2000 rpm. When I drive and come to a stop it will idle at around 2000 to 2800 rpm then after about 10 seconds will slowly drop down to around 650 to 700 rpm, what I consider a normal idle. This is a constant problem that has been happening for about the last month.Any ideas?
Thanks,John
EMAIL=barnesjtsl@yahoo.com]barnesjtsl@yahoo.comEdited by: sw2cam
Old Jan 24, 2008 | 05:33 PM
original007's Avatar
probable cts issue remove the connector and check for corrosion on the pins they sometimes crack and leak into the connector or just reading low
Old Apr 30, 2008 | 12:23 AM
saturnpower's Avatar
I had high idle issues with my sl2, changed the throttle positon sensor and the coolant temp sensor and my car is super quiet now.
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
cloudsplitter8
Aug 24, 2012 07:47 PM
tiny747
Oct 29, 2006 06:52 PM
x86guru
Jun 17, 2006 04:24 PM
xvin99
Jun 14, 2006 09:00 PM
Slick2005
Engine & Internal
Nov 2, 2005 01:02 AM
