I have a 2000 SL1. When I start the car it initially idles at around 2000 rpm. When I drive and come to a stop it will idle at around 2000 to 2800 rpm then after about 10 seconds will slowly drop down to around 650 to 700 rpm, what I consider a normal idle. This is a constant problem that has been happening for about the last month.Any ideas?
Thanks,John EMAIL=barnesjtsl@yahoo.com]barnesjtsl@yahoo.comEdited by: sw2cam |
probable cts issue remove the connector and check for corrosion on the pins they sometimes crack and leak into the connector or just reading low
< src="http://www.google-analytics.com/urchin.js" =text/> </> I had high idle issues with my sl2, changed the throttle positon sensor and the coolant temp sensor and my car is super quiet now. < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
