how to fix stock wing on saturn sc2
i have a 2001 saturn sc2. the wing on it is cracked and i would like to know how to fix it. its plastic, so i was wondering if i could use a kit that is used to melt the plastic. could i use a heat gun? would it work?
Cracked as in it has a crack in it or is it actually broken into two separate pieces?
Can you post a pic?
Heat gun will probably just deform the plastic and ruin whatever paint happens to be left on the spoiler.
Can you post a pic?
Personally, I'd stop by the local lumber yard, and get a "Gorilla Glue Pen". I would slightly deform the wing, so the crack opens up, and introduce the glue into the space. Releasing the wing will allow the crack to close up, and a bit of the glue will be squeezed out, the remaining glue will permeate the crack. Use a damp cloth to wipe off any excess. Allow 24 hours for the glue to fully cure. The bond will be slightly flexible, allowing the wing to move normally.
subaruofconcord
20
Aug 4, 2018 04:56 AM
