help please probleme motor
Old Apr 18, 2014 | 07:28 PM
lechateau's Avatar
Default help please probleme motor
Hi have SL1 1,9L 2001, the probleme is when I drive the motor becomes hot and stops, and when it cools it starts again,
thanks
Old Apr 18, 2014 | 09:29 PM
lechateau's Avatar
ok I check with the OBD in the code is p0340
Old Apr 19, 2014 | 12:08 AM
0340 is ignition related. We'll deal with that later.
Sounds like your car is overheating.
1) are you loosing coolant?
2) Is the underhood auxillary fan right behind the radiator turning on when the temp gauge reads above 3/4? You can also test it by engaging the A/C and turning it on. Do so with a friend with the hod up so you can hear the sound.
Old Apr 19, 2014 | 11:22 AM
lechateau's Avatar
ok thanks I check that
Old Apr 19, 2014 | 09:39 PM
Dtruck1's Avatar
He might be meaning it shuts off like a bad coil does when it gets hot.
Old Apr 20, 2014 | 10:59 PM
or maybe a cps
or maybe we may never know if he doesn't come back with more info......
Old Apr 21, 2014 | 09:58 AM
Do you think he'll come back?
Old Apr 21, 2014 | 02:35 PM
lechateau's Avatar
I change the cable and spark plug, clean the coil, and try never make the probleme
thanks
Old Apr 21, 2014 | 02:54 PM
I have no idea what half of that post means.
Old Apr 21, 2014 | 07:32 PM
IF the engine is over heating so high it shuts down good luck with having an engine left.
