Gauges Die!?
Old Dec 13, 2009 | 04:12 PM
Raab_himself's Avatar
Default Gauges Die!?
I just picked up a '99 sl1, when driving at an idle in 5th (2000rpm) the speedo and tach will go dead then reset themselves...the e-brake light also comes on. They will drop down to zero then reset and go back to normal. the fuel and temp gauges don't change though. the car doesn't run any different and i cant seem to figure out what sets it off. Any help would be appreciated.
Old Dec 13, 2009 | 06:00 PM
Check the output AMPS and VOLTAGE of the alternator under LOAD.
Old Dec 13, 2009 | 07:19 PM
Also check the positive battery cable for any corrosion, replace if you find any inside of the cable itself.
Old Dec 14, 2009 | 12:42 AM
k thanks i will try that out and let ya know
Old Dec 15, 2009 | 11:32 AM
so i got it tested and apparently there is a diode fault. but now i gotta rip half the engine apart just to get at the thing?!?! haha is it just a matter of taking the powersteering pump off or is there a better way???
Old Dec 15, 2009 | 11:32 PM
through the wheel well is also an option (removing plastic liner of course)
Old Dec 16, 2009 | 11:03 PM
yeah well it will probably have to wait a bit, too cold to work in the unheated shop right now. also...much to my surprise the negative battery cable was actually ever so slightly loose, since tightening the gauge death hasn't happened. will wait and see if that was the easiest fix ever.
lukesteeler89
Jan 30, 2010 08:16 AM
wesuhlee
Nov 23, 2008 07:31 PM
Leonardjohn
Oct 27, 2008 05:20 PM
billgrim04
Engine & Internal
May 30, 2008 03:28 PM
fish87
Mar 10, 2006 03:47 PM
