Engine Swap on SC2
Old Nov 26, 2007 | 10:53 AM
LosTyger's Avatar
Greetings, all,
I recently got a 15k mile engine from an SC2 to replace my current 212k mile engine. I'm hoping to do the swap over New Year's.
The question becomes, what should I look to replace while I got the engine out? I have a clutch kit that I'll be doing. What about engine mounts? Use the old ones or get new ones? New distribitor cap or old one?
Also, the new engine has been sitting idle for a while. What should I do to it before I start it up? Anything you'd recommend?
Old Nov 29, 2007 | 06:06 PM
Low Saturn's Avatar
Actually my question is what year Saturn do you have and what year engine is going into it? Edited by: Low Saturn
Old Dec 2, 2007 | 06:47 PM
I guess he has no idea.
Old Dec 14, 2007 | 07:04 AM
LosTyger's Avatar
Sorry; I was on the road & forgot to check the thread...It's a 2000 SC2 and I believe the motor is either a 2000 or 2001.Edited by: sw2cam
Old Dec 23, 2007 | 12:11 PM
Low Saturn's Avatar
I will be a direct swap. Before starting the engine, prime it with oil and fuel.To prime it with fuel, turn the key from the off to the run postion (without starting the engine). Leave it in the run position for five seconds, turn it off and repeat five times.To prime it with oil, remove the electrical connector at the coil packs and crank the engine for 45 seconds to a minute. This will get oil throughout the engine so you dont start up a dry engine. Plug the coil packs back in and fire it up.Edited by: sw2cam
mcalkins3
Jan 25, 2010 10:13 PM
zodszoo
Mar 17, 2008 11:20 PM
robert86
Mar 5, 2008 11:01 AM
thoken
Jun 13, 2005 10:27 AM
jschrader
May 11, 2005 07:19 PM
