Engine learnig curve,,,the hard way
Old Aug 28, 2015 | 01:32 AM
echo1's Avatar
Default Engine learnig curve,,,the hard way
Hi All,
Rescued an '00 SL2 from a Goodwill donation center, because I'd heard some positive things about the platform, and I don't buy Asian.
Clean car, 110K miles, 5 speed, straight, passed Kali smog, should be sound right. First tank of gas used a half a quart of oil, and started to smoke about 3K miles later, consuming more oil. Checked the compression, #3 was dead, figured valves. I parked it and jumped back in my S10.
18 months later, I had a friend tear it down for a valve job, his labor for a 1200 VW rebuildable core, I buy what ever it takes to get my Saturn online.
When he pulled the head, the crown and top of #3 piston was gone, #2 had a chunk out of it exposing the 1st ring for a 15 degree arc. It still ran but made big smoke.
Since then I've seen a number of CL cars with bad a #3.
What causes that? PAX
Old Aug 29, 2015 | 12:32 AM
so it ran on two cyls and blew smoke through the other two.
Cyls were prob running lean due to clogged injectors, raising combustion chamber temps. Throw in some detonation and maybe some preigniton, and you get what we have right here.....which is the way he wants it.....well. he gets it....
Howard_Woodard
Jan 5, 2014 02:58 PM
rileysowner
May 26, 2012 06:03 AM
dbhost
Dec 7, 2011 05:14 PM
clgarrison
Oct 28, 2009 09:46 PM
DamSam
Nov 26, 2007 02:24 PM
