couple questions
Old Apr 26, 2011 | 12:04 AM
scdohc2's Avatar
Question couple questions
so ive got a 97 sc2 5speed i wondered are there any forms in which the is prone to break itself, does it have any common issue within the motor that tends to go for example a bearing being spun or oil pump dying quick or a rod snapping anything like that?
and also are sc body panels exchangeable with the sc2?
Old Apr 26, 2011 | 09:28 AM
Are you asking about same year vehicles, or a range of years?
Old Apr 26, 2011 | 01:12 PM
fm2200's Avatar
I think he's asking what are the most common problems that occur in Saturns in general. I had heard that for some the pump in the trans is prone to premature failure, overall I'm not knowlegable enough to say. The front springs on the strut's are not long lasting at least on the SL & SC.
Old Apr 26, 2011 | 03:15 PM
scdohc2's Avatar
fm2200 is right im aksing about genreal saturn motor issues
Old Apr 26, 2011 | 11:26 PM
Some people have reported oil usage of as much as a quart/1000mi. Argument is still open as to the cause (bad rings, bad valve guides, etc.). Others (like myself) have run their vehicles into the 150,000 mile + range with no appreciable oil usage.
Older engines had problems wth the Engine Coolant Temperature Sensor (ECTS). Original device had a resin coated sensor tip witch would fail, causing the air/fuel mixture ratio to go either very rich, or very lean. Darned part (with a metal tipped sensor) only costs about $15 usd, but it can cause a host of starting problems.
Old Apr 28, 2011 | 01:43 AM
scdohc2's Avatar
alright, well ill be putting in a new motor soon and as i do so ill have to see, i imagine some new gaskests and seals should help the problem as well and maybe run a thicker oil
Rubehayseed
Jul 5, 2015 11:33 AM
Judobrad
Oct 14, 2013 06:49 PM
silver04saturn
Mar 17, 2010 04:16 PM
Digit4lPyro
Feb 27, 2010 07:56 PM
Rick76
Oct 11, 2006 12:52 AM
