The cooling fan on the 2000 SC1 only comes on when you turn the defroster on , My little stepbrother said it started doing that after he installed a radio system in it when he had it . Also there is a ground wire just hanging loose behind the console under the radio , could that be a problem because everything else works
2000sc1 ...
Clarification, please. You say ''cooling fan'' in your message. Do you mean the fan that is mounted in the passenger compartment, or are you referring to the fan mounted on the radiator inside the engine compartment? |
The radiator fan is what I am talking about . Sorry should have made that more clear .
200sc1 ...
Disconnect the Engine Coolant Temperature Sensor (ECTS) connector, and with an ohmmeter, measure the resistance of the contacts on the sensor when the engine is cold. With the outside temperature between 50degrees and 80degrees, the sensor should read anywhere from 5,600 ohms to 2,400 ohms. If it reads much more, or much less, replace it |
Thanks will try that wed. it is supposed to be around 60deg out that day .
When you set the air flow to defrost the windshield, it automatically turns on the air conditioner to de-humidify the incoming air so it doesnt fog up the windshield. When ever the A/C is on, the fan is on.
GOt it fixed , replaced the ects and it is fine now . Thanks all
2000SC1 ...
Glad to hear you are fixed and back underway. Happy New Year ... |
