clutch cylinder with air!
Old Nov 16, 2006 | 02:05 AM
spoon's Avatar
hi everyone!
I own a SL200 - 2001 - 4cyl. 150000 KM
Since there's some air in the clutch system, I found the way to bleed it with he bleeder located at the top of the slave cylinder clutch.
Problems is that I have to bleed alomost everyday....
Driving slowly with frequents stops won't cause any problems;
Driving at medium/fast speed for 15-20 min will cause the clutch pedal to loose resistance; by pumping the pedal 7-8 times, pressure will come back... or If I have time, just have to stop and reopenes the bleeder to get the air out.
I've been told that the slave cylinder clutch is available as original parts only and come with the clutch kit.... which is real expensive to have it replace!
Any way to replace it?
Would air get into system through something else??
Oil level in the master cylinder reservoir never get down... guess there's no leak..........
Please help!!!!!
Thanks
spoon
Old Nov 16, 2006 | 08:59 PM
You can buy the slave cylinder assemblyfrom Saturn without buying the disc and other related clutch parts. Edited by: sw2cam
Old Nov 29, 2006 | 09:41 PM
spoon's Avatar
Finally fixed!
Clutch kit including slave cylinder - 1 year warranty /25000 km
and flywheel refaced ; $760.00 instead of $1750.00 at the dealership.
Let's wait for next problems... lol!!!!
Thanks
Old Nov 30, 2006 | 12:04 AM
Wow..................lucky you.
jenmetcalf5
Jan 3, 2018 08:12 AM
blaisa
Mar 15, 2014 09:31 AM
catman021
Dec 28, 2009 07:30 AM
2000saturnsl2
Mar 16, 2008 04:28 PM
betinaq
Jun 13, 2005 10:19 AM
