changing gear oil 98sl
Old Nov 16, 2009 | 04:29 PM
turbochargedv8's Avatar
Default changing gear oil 98sl
might be able to get my 98sl to school and use the lift would this be straight forward changing the gear oil or is the drains in an odd place any write up or tips so i don't look more tarded than i already am
Old Nov 16, 2009 | 11:31 PM
saturnsdn's Avatar
its pretty straight forward. drain on bottom fill from top where dip stick is. the trans uses atf regardless if manual or auto
Old Dec 9, 2009 | 08:08 AM
roberank's Avatar
I encounter the same problem as you sir.
And now i ask my brother to fix it.
any advice to make it more faster but
can assure the safety?
s10blazer99
Feb 26, 2011 03:35 PM
turbochargedv8
Dec 26, 2009 11:17 AM
turbochargedv8
Nov 15, 2009 07:18 AM
ASKBCG
Oct 20, 2007 08:34 PM
X-Vert
Mar 3, 2007 09:48 PM
