cant pass smog.lots of soot in exh.pipe
Replace the ECTS and connector with gm genuine parts. You are likely running way rich... more than intended when cold. When the ects goes bad it usually goes open circuit which corresponds to the ECM interpreting the coolant temp as -40 ish. Yours may not be open circuit but if there is corrosion or poor electrical connections, the circuit resistance increases and is interpreted as the coolant temp being cooler than it really is. air/fuel skewed rich. If you had an injector stuck open I don't think the issue would clear up as you.drive. and the ects pretty much never throws a code b c -40 is sill considered within normal operating range.
If your pre cat was plugged, I'd think you would have significant performance issues.
Timtheelite2025
Mar 21, 2019 08:37 AM
Maroon97SL
Jun 6, 2011 05:22 PM
