Braided stainless brake lines
Old Nov 1, 2007 | 06:14 PM
blue99sc2's Avatar
Does anyone know where I can get some braided stainless steel brake hoses for a 1999 sc2 with an automatic and rear drum brakes? I only need the front lines. I've been searching Google for the past hour and I can find kits for the first generation S-cars, but I can't find anything that will fit a '99.
If anyone knows of another solution to my problem, I'm open to suggestions.
The left front brake hose is rubbing against something, and it's work through the plastic outer coating, the outer rubber part of the line, and whatever it's rubbing on is starting to wear through the braided nylon section of the brake hose. If it was my DD, I'd just throw another stock line on it and not care, but it's my wife's car, and she doesn't pay attention to what it tells her, until something on it completely fails. I really don't want to get a call around midnight saying that she rear-ended a car because her brakes failed.
I can't tell what the brake hose is rubbing against, since there's no rub marks on anything other than the brake hose. Based upon where the wear is on the hose itself, I think it's rubbing on the plastic shield on the side of the transmission, although I've never seen plastic cause wear like that. Thanks in advance.
Old Nov 1, 2007 | 08:54 PM
blue99sc2's Avatar
Never mind, I found some.
bjking
Jan 19, 2014 01:41 PM
purplemotoman
Aug 3, 2013 08:25 AM
Painter
Jun 19, 2007 06:14 AM
dbswayne
May 20, 2007 08:00 AM
toby
May 13, 2005 06:51 PM
