anyone know what could be wrong with this
Old May 28, 2008 | 06:55 PM
swansonblake's Avatar
Im considering purchasing a used saturn. i have owned the 93 sl2 before and it is a great vehicle. i found one dirt cheap but the owner that posted this described this problem....
* It starts and drives(very slowly) because the transmission is not engaging right and the engine light is coming on. *
a clutch? flywheel? or the entire trans?
please help!!!Edited by: sw2cam
Old May 28, 2008 | 11:29 PM
Low Saturn's Avatar
Could be something as simple as stretched shift cables.
Old May 29, 2008 | 12:26 PM
Vultures Eye's Avatar
I think you changed the filter on the valve
body. If you weren't having trouble before you changed everything, suspect the
o ring on the filter inlet side or a lack of one.
It is better to take your car to a pro. You
will damage your transmission if you keep driving it.
Edited by: sw2cam
Old May 29, 2008 | 12:38 PM
Low Saturn's Avatar
Originally Posted by Vultures Eye
I think you changed the filter on the valvebody. If you weren't having trouble before you changed everything, suspect the o ring on the filter inlet side or a lack of one.
Manual transmissions dont have valvebodies. Plus he hasnt changed anything yet. He doesnt even have the car
Old May 29, 2008 | 08:20 PM
Could be the chrome muffler bearing, but you'll need a left handed monkey wrench to remove it.
Old Jun 26, 2008 | 12:00 AM
only1jack's Avatar
[QUOTE=sw2cam]
dont take to jest anybody i got my cluche changed by a "pro" he outsourced it to some unlicened moron whoused a impact wrench on the drain plug and cracked the transmition and noting i could do because the guy wasnt even licened.
with a problem like that no wounder its dirt cheap i would never buy a car that is alredy having problems
Old Jun 26, 2008 | 05:07 PM
95_sl1's Avatar
[QUOTE=only1jack]
It is better to take your car to a pro. You will damage your transmission if you keep driving it.
dont take to jest anybody i got my cluche changed by a "pro" he outsourced it to some unlicened moron who used a impact wrench on the drain plug and cracked the transmition and noting i could do because the guy wasnt even licened.
i test drove a 91 honda prelude once that had serious problems in 2nd and 4th, and would not even go into reverse, the girl spent over $1000 to have the clutch replaced and then started to have the problems, turns out the place that did it damdaged the shifter cables.
and replaceing the trans (if you have the mechanical ability) is not that bad as long as your carefull not to damage any of the sensetive parts of the clutch system. i bought my 95 sl1 for $125 because the trans was bad (the final drive pin was broken) and replaced it myself for $75.
sl2mmed
Suspension
Jun 11, 2011 09:09 AM
mcvicar88
Feb 6, 2011 08:15 PM
carterseth32
Nov 2, 2009 06:45 PM
blusaturn1
Mar 18, 2009 11:58 PM
blusaturn1
Feb 18, 2009 04:36 PM
