99 SL2 Power Locks gone crazy..
Old 10-01-2007, 06:32 PM
imaukfan's Avatar
My power locks have gone crazy. They will no longer work to lock or unlock the doors, but at times just start clicking and that button that locks and unlocks the door is jerking by itself. Is there a way to just disconnect these, since I don't have the $$ to get them fixed?
Old 10-02-2007, 10:05 PM
Sounds like a loose power or ground connection.
Pulling the fuse is an option, but there are likely other devices sharing the same circuit that will then cease to function.
Check the owner's manual to see exactly what is on that fuse before deciding whether or not to pull it.
Derf
Old 10-05-2007, 11:54 AM
imaukfan's Avatar
I don't have an owners manual with my car. Is there anything online I can look at?
Old 11-05-2007, 07:48 AM
saturn99's Avatar
Did you ever find out the cause of your locks going haywire? Did you
remove any fuses or relay.
Old 11-12-2007, 10:20 PM
bcpolster's Avatar
This is also happening to our 99 Saturn SL.
Old 01-04-2008, 04:33 PM
original007's Avatar
May sound strange but is your key worn? worn keys will allow the key to removed before the door lock cylinder is centered so the switch mounted to the door lock cylinder is partially engaged this will result in the condition you described.
waynerds2000@aol.com
01-08-2014 02:11 PM
09-27-2012 09:40 PM
cellocellocello
10-13-2009 10:47 PM
TWOOD
03-19-2009 04:31 PM
pester
09-05-2008 03:25 PM
Quick Reply: 99 SL2 Power Locks gone crazy..
