’99 SC2 stalls
Old Sep 12, 2005 | 07:44 PM
wyldside's Avatar
Hi! My wife has a '99 SC2 that randomly dies and will not restart. When
it chooses to stall everything shuts down including the radio. You can
turn the key to engage the starter but nothing happens. It doesn't
matter if it's highway or city driving. It just dies. Then suddently
after a few minutes, you can turn the key and it will start up like
nothing is wrong. It is a problem that comes and goes with frequency
and has been getting worse lately. Today she was left stranded in the
middle of a busy intersection. I'm am guessing that it's the main relay</span>
or Ignition Module but I'm not sure where it's located on this vehicle.
I don't have anything to scan the ECU for CEL codes and I guess her car
doesn't have a Self Diagnostics since it's OBDII. Does anyone have
suggestions or had the same problem happen to them?
Old Sep 18, 2005 | 03:50 AM
wyldside's Avatar
Okay, since no one can help me there, Does anyone have an Electrical
Schematic of the '99 SC2? Also, where is the location of the main relay?
Old Oct 17, 2005 | 03:28 AM
rick_ryder's Avatar
lots of problems with the negative terminal on the battery. bat terminal cracks inside the battery causing the exact problem you are having. pull of the negative treminal and check for any corrosion or clear fluid(battery acid) if so replace the bat and the terminal end of the cable. Just about all saturn shops keep these ends in stock cuz we replace so many of them. keep me posted.
kens
Mar 1, 2009 08:59 PM
superspeeder
Jan 19, 2009 10:27 AM
imp81318
Jul 17, 2008 08:31 PM
99SC2GA
Jun 28, 2008 09:58 AM
PDX_92SL2
Oct 19, 2006 01:31 AM
