98 Saturn Stalls
Old Jul 30, 2009 | 02:46 PM
Raff Worth's Avatar
Default 98 Saturn Stalls
I have a 98 Saturn 1.9. The car starts ok and Idles OK, but when you start off it stalls or almost does then catches and runs fine. Every stop sign is a worry cause it will hesitate and sometimes stall. No codes show up on scanner. Any help would be appreciated
Old Jul 30, 2009 | 10:27 PM
Ever change ECTS and connector?
Ever clean EGR valve?
Old Jul 31, 2009 | 01:51 PM
Raff Worth's Avatar
I have not changed anything yet !! Looking for some guidance before just replacing parts
Old Jul 31, 2009 | 09:15 PM
I asked you if you had done either of two things I mentioned to narrow down the most likely cause.....
ECTS by far most common issue due to design flaw in original OEM part. Replace with brass style replacement. Replace connector (dealer only item).
Old Jul 31, 2009 | 11:12 PM
Raff Worth's Avatar
Thanks, I will give it a try
Old Aug 4, 2009 | 08:05 PM
Raff Worth's Avatar
Replaced the ECTS and it runs great !!! THANKS BIG TIME !!!!!!
Raff
Old Aug 4, 2009 | 08:44 PM
another one restored to former glory
scifime2
Jul 16, 2016 12:07 PM
derin6770
Jul 8, 2010 05:41 PM
jllacourse
Aug 21, 2009 03:54 PM
flamesrock
May 31, 2008 10:52 PM
wyldside
Oct 17, 2005 03:28 AM
