95 sc2 kills
Hi, New member here. Great to be here and thanks for the help in advance. I have a 95 Sc2 with 148,000 auto that runs fine 99% of the time. Everything seems fine, it will start to run rough and stalls, put it in neutral and it will start immediately and run fine. It usually does this on deceleration, but sometimes at cruising speed (45to60). No consistency to when this happens, once a day then not for a few days. It has been doing this for over a year (kids car) No codes show, and the dealer couldn’t find anything. Someone suggested fuel pump. Any help would be great Thanks
Suspect your EGR valve is sticking (intermittently). As the miles rack up on the S car engines, so does the carbon buildup which is exacerbated by the oil burning.
Remove and clean EGR and the two ports it attaches to. Carb/Choke cleaner works pretty good. The pintle should move freely.
Derf
Derf
