2004 l300 a/c problem
Old Jul 1, 2011 | 08:45 AM
dzt41j's Avatar
Default 2004 l300 a/c problem
Can't find a leak in a 2004 L300 (v6). Freon empties in about a day. Put dye in the system without finding any leaks. System does get very cold immediately after re-charging.
Anybody have any common spots they have found leaks? Hoping it's not the evap. I did look under the dash and checked the drain tube water for dye.
HELP! This is a pain.
Old Jul 1, 2011 | 10:32 AM
May need to get a sniffer ....
Old Jul 2, 2011 | 08:09 AM
Wow! Empties in a day - that's a significant leak. Since you find no dye in the evaporator coil, I'd look at the condensing coil fittings up by the radiator. I fully agree with sw2cam -- a sniffer would be like totally helpful in finding where your charge is going .......
Old Jul 2, 2011 | 10:01 PM
Thats a big leak ... may just be the evap.
Old Jul 4, 2011 | 06:45 PM
dzt41j's Avatar
Do the sniffer's work a lot better than the dye/black light?
I meant I can't really check the evap without tearing the dash apart. If it is the evap though is it worth it...
pain in the butt!
Old Jul 5, 2011 | 07:20 AM
Frankly, I don't use a black light at all to check for leaks - the sniffer is the way to go
gemelk
Audio/Visual Electronics
Feb 17, 2017 05:00 PM
bjking
Jan 19, 2014 01:41 PM
Hooch80
Feb 15, 2012 10:58 AM
jeepercreeper
Nov 17, 2010 07:15 PM
Northcutt042
Aug 8, 2009 09:52 PM
