2004 Ion Fan Speed Switch Going Bad
I already know the resistor is out, as it only works on 4 (highest setting), but a new problem has now developed.
When on 4, it started going in and out (bumping the switch made it work again). It slowly (over a few weeks) got worse and worse until now, I have to push in and twist the switch and hold it in order for the fan to work.
I really don't want to pay a dealer... Is this something I can fix myself? Has anyone else had this issue and fixed it?
Okay, good to know. Thanks for the heads up.
So I see that I can indeed go this route 2003 2004 2005 2006 2007 Saturn ion A C Heat Climate Control | eBay
I'm wondering if I can simply replace the switch itself though. Seems like I shouldn't have to replace the whole head when only one component is out.
Maybe that's just how it goes though?
That's what you need alright. The resister many, many times is a melted down contaction. Most times repairable by replacing the male connector after removing melted plastic. Another thing RjION showed me how to repair.
