2003 Vue AC problem
Old Jul 18, 2006 | 06:31 AM
jimbob's Avatar
AC clutch cycles quickly(less than a second) but not often,maybe every 10 seconds.All lines,receiver leading to and from compressor are clear.If I jump out the compressor I climb to a high head (up to 350lb)and high back of 40lb. and the engine will stall.Trying to figure whats wrong and wonder how sytem is controlled?There appears to be a "Pressure Sensor and Pressure Sensor Valve mounted to the compressor on the manifold holding the liquid and suction line.Could this be the problem?I don't know what it controlls!!
Any help appreciated
Jim
Old Jul 19, 2006 | 01:05 AM
3/36 warranty?
Old Jul 19, 2006 | 07:46 AM
jimbob's Avatar
Just out of warranty on time and miles.
Old Jul 26, 2006 | 01:17 PM
If you are low on 134a the system will cycle on and off. Add 134a then check for leaks.
bowbowx
Jan 20, 2016 03:02 PM
scifime2
Jul 22, 2015 01:34 AM
1kevinmac
Mar 6, 2011 08:52 PM
CALegalVette
Sep 4, 2007 07:34 AM
prawlings1
Aug 5, 2007 02:33 PM
