2001 4cyl Interference Motor?
Old Apr 14, 2008 | 03:37 PM
  #21
Easywin's Avatar
That's what I am afraid of.
But, the oil filter had 11-5-07 written on it, the oil was pretty dirty, and there was sticker from Wal-mart on the windshield with a date about 3 months down the road.Edited by: Easywin
Old Apr 28, 2008 | 03:52 PM
  #22
Easywin's Avatar
I did my compression tests again, I got much better numbers this time. I used oil in the two that had 80 and 95 beforeI did the test again, [img]smileys/smiley4.gif[/img] , but on the other two, I did them dry then added the oil. I didn't get any different numbers than before. Then, I did them again with oil, the one with 0 stayed there, and the one that was good before read as high as the other two.
So I have three good cylinders and one shot. What could cause one cylinder to go bad? Would that indicate a head gasket. I was told by someone at work that Saturns are known for blown head gaskets. Is this true?
Old Apr 28, 2008 | 04:08 PM
  #23
Low Saturn's Avatar
SOHC's are known for cracked heads. You have to really neglect the engine or be doing something dumb to blow a head gasket on a DOHC.
Sounds like a cracked piston or bent/broken valve.
Old Apr 28, 2008 | 04:54 PM
  #24
Easywin's Avatar
How would the piston crack or bend a valve? I think the engine might have been neglected, but the oil had been recently changed.
I guess I will find out when I take off the head, right? Do the timing cover and all the accessories need to come off to get the head off?
Old Apr 28, 2008 | 05:04 PM
  #25
Low Saturn's Avatar
The timing cover has to come off. The water pump, alternator and A/C compressor can stay.
Old Apr 28, 2008 | 05:11 PM
  #26
Easywin's Avatar
Power steering?
I take it all of the accessories don't mount on/near the timing cover.
Old Apr 28, 2008 | 05:17 PM
  #27
Low Saturn's Avatar
The pump doesnt have to be removed, the it does need to be unbolted and moved out of the way if I remember correctly. I usually do this with the engine on a stand.
Old Apr 29, 2008 | 05:04 PM
  #28
Easywin's Avatar
Well, I am going to pull the head with the engine in the car, so I won't get the luxury of doing it on a stand. It does make it much easier.
Do I need to completely remove the intake and exhaust? Or can I remove the bolts/studs and pull them out of the way and secure them so they don't fall back in my way.
Old Apr 29, 2008 | 05:18 PM
  #29
Low Saturn's Avatar
Just leave the manifolds attached to the head. Then pull everything out together.
Old May 3, 2008 | 01:57 PM
  #30
Easywin's Avatar
Broken rod? I decided to do one more thing before I took off the head. I remembered reading someone putting a drinking straw down the spark plug hole to see if the piston moves. I thought I would go ahead and try it. Nothing! I thought I was doing it wrong so I tried it on number two and it moved. I am pretty sure something broke on the bottom end. I just don't know why.
How easily accessable is the crank from the bottom of the car with the engine installed?
*Edit*
Thrown rod! I found a hole in the front of the block, just above the pan, of course! It couldn't have been just the pan.Edited by: Easywin
Greg80
May 29, 2013 08:38 PM
adamglover29
Feb 7, 2013 06:38 PM
wapayne
Sep 7, 2011 08:54 AM
Baobab
Jul 10, 2010 09:29 AM
scbatteringram
Apr 22, 2007 11:09 PM
