2001 3 dr coupe
Old Sep 5, 2010 | 10:03 AM
pecos130's Avatar
Default 2001 3 dr coupe
when i turn key on all instrument panel lights come on,after a couple seconds they all go out,,hear a click that sounds like it is in dash when this happens,,about 4 seconds later water and battery lights come back on,,when turn key to start,hear the cick again,,all power is lost momentarily,car will not start,what may be causing this?car is automatic trans
Last edited by pecos130; Sep 5, 2010 at 10:16 AM. Reason: thought may make a difference if standard or auto
Old Sep 5, 2010 | 12:15 PM
I am assuming that you have already checked the battery (know it to be good), and have made sure the ground cable from the battery to the chassis is not internally corroded/defective -- right?
Old Sep 5, 2010 | 12:56 PM
pecos130's Avatar
yes,checked battery and cables,also nuetral switch,, after turning key on ,hear click and all dash panel lights go out
Old Sep 5, 2010 | 12:58 PM
pecos130's Avatar
Default 2001 saturn
the click i talking about seems to be coming from inside dash,passenger side
Old Sep 9, 2010 | 06:19 PM
i tend to think this is still a battery issue, as the clicking may be some relay in the dash IPJB that is chattering b/c it is losing voltage when you turn the key to start the car.
Can the car be jump started? IF so, can the car be restarted after being jumped and running a bit (to charge your batt)?
lukesteeler89
Mar 19, 2009 04:14 PM
saturn03
May 13, 2008 07:13 PM
secondsaturn
Sep 17, 2007 08:51 AM
blksti04
Mar 1, 2007 05:21 PM
makenzie71
Jun 11, 2006 02:49 PM
