2001 3 dr coupe
when i turn key on all instrument panel lights come on,after a couple seconds they all go out,,hear a click that sounds like it is in dash when this happens,,about 4 seconds later water and battery lights come back on,,when turn key to start,hear the cick again,,all power is lost momentarily,car will not start,what may be causing this?car is automatic trans
Last edited by pecos130; Sep 5, 2010 at 10:16 AM. Reason: thought may make a difference if standard or auto
i tend to think this is still a battery issue, as the clicking may be some relay in the dash IPJB that is chattering b/c it is losing voltage when you turn the key to start the car.
Can the car be jump started? IF so, can the car be restarted after being jumped and running a bit (to charge your batt)?
