1999 SL2 with new ignition
Old Dec 31, 2020 | 01:51 PM
Don Berger's Avatar
Default 1999 SL2 with new ignition
I can’t get rid of p0340 code. I replaced ignition control module. Any suggestions?
Old Dec 31, 2020 | 08:12 PM
You only need to post your question in one post.
Thanks
Andy
Old Dec 31, 2020 | 10:49 PM
P0340 indeed indicates an ignition system issue.
Ignition control module ICM is a very expensive guess, unless you meant ignition switch.
Take out the Platinum iridium exoticum plugs and replace them with OEM Saturn dohc plugs
ngk 5643 BKR5ESA-11
read one of the many posts about waste spark ignition systems.
Clean corrosion off your coil tower posts with Emery cloth. Same for both ends of each spark plug wire. The metal part. Dielectric Grease at all connection points.
Be sure there is no oil puddling around the boot of the plug wires in each plug well. It can get wicked up into the boot and divert the electricity from the end of the plug wire, thus interfering with the spark.
P0340s are almost always plug related, wire related, poor connection at plugs or coil towers, valve cover gasket leakage near plug wells.
Or it is plug related, plug related, or plug related most often.
Happy freaking New year
Old Jan 4, 2021 | 02:45 PM
Don Berger's Avatar
Thanks for your help. The reason I replaced the ignition module was because the engine was only firing on two cylinders. After the replacement,(plus plugs and wires) the engine runs fine. I just can’t get that code P0340 to go away.
Old Jan 4, 2021 | 03:17 PM
Did you put in the Saturn stock plugs I indicated above?
Most common reason for that code on a saturn s car is use of non-stock plugs which throw p0340 errors. Has to do with how the ignition system is configured.
Get the Platinum plugs out of there.
Let me guess. One and four or two and three we're not firing properly. Did you buy just the ignition control module or also the coils?
Old Jan 4, 2021 | 08:32 PM
Don Berger's Avatar
I replaced the coils as well. I will check the spark plugs but they are not fancy platinum. I don’t get why I’m getting this code when the car runs great.
Old Jan 4, 2021 | 09:35 PM
Please reread all of my posts on this thread. I have told you three times the most likely source of the remaining code and how to get rid of it.
You show no interest in following advice you claim to seek, so stop asking.
Done here
Sydthesaturn
Dec 17, 2019 01:13 AM
wyndance
Nov 7, 2012 09:37 AM
msiscrm
Jan 31, 2012 08:56 PM
miami man
Apr 20, 2010 11:12 AM
bcantara54
Nov 10, 2009 09:21 PM
