1997 SW2 Power Steering Brackets
Old Sep 14, 2006 | 10:15 PM
alunga's Avatar
I just finished replacing the cylinder head on my SW2. I know where to
put everything back EXCEPT for one part-a small black bracket which I
found lying under the car after I had moved the power steering pump
aside. It's not the readily visible one that bolts to top of the intake
manifold, but looks very similar. There is an apparently unused bolt
hole just up from where the timing belt tensioner mounts. Does the
bracket mount to the back side of this, and where exactly does the
other end go? I've spent close to an hour under the car trying to
figure this out.
Old Sep 14, 2006 | 10:18 PM
alunga's Avatar
I meant to say SERPENTINE belt tensioner, not timing belt.
Old Sep 18, 2006 | 11:37 PM
onesmartscdt's Avatar
alunga
Send a picture it is worth a million words.there is a bracket under the intake and directly behind the alternator not easy to get to but a distinct possibility.the bracket is offset with tube center and flatened on both sides with a single hole on each end.No longer then 4or 5 inches
Darryl T
JEKoenig0524
Feb 22, 2015 06:43 PM
dbhost
Dec 6, 2011 04:03 PM
saturne20
Aug 1, 2008 10:14 AM
lynn
Saturn L300
Sep 12, 2006 02:10 PM
