’’01 ignition switch frozen
Old 08-13-2008, 11:15 AM
rosett's Avatar
I''ve been having some trouble with the ignition switch in my 01 saturn lately-stiff, hard to turn the key. So I shot a little graphite in and turned it on and off a couple of times. All of a sudden, it froze up, not quite in the lock position. I can get the key in and out, and tried both the keys I have-no dice.
So what next? Do I have to replace the switch? I did some reading up on another website, and it talked about having to remove the steering wheel. I took the top cover behind the wheel off, and I can see and get to the metal housing that holds the switch. I can also see a small hole on the top, towards the dashboard. Is that where you push in a pin to release the switch from the housing? Also, I''ve read that some Saturns need to be reprogrammed when yo put in a new switch. Is that true of this model? It''s just a plain, basic sedan. Thanks for any help.
Old 08-13-2008, 11:57 AM
rosett's Avatar
I should add that from what I''ve read, the switch has to be in the "acc" position for the switch to be removed. This one is jammed between "locked" and "acc".
daveinbuffalo
03-14-2008 11:15 AM
tsmith1947
01-26-2008 12:44 PM
gookdog69
01-04-2008 06:34 PM
paul
10-26-2007 09:57 AM
jess
08-04-2007 09:53 AM
Quick Reply: ’’01 ignition switch frozen
