Valvoline restore and protect. 95 sl2 twin cam
Old May 17, 2025 | 08:27 PM
Eli Smith's Avatar
Default Valvoline restore and protect. 95 sl2 twin cam
Just did oil change at 223000miles on my auto 95 sl2 and was wondering how long I should keep valoline restore and protect in there till I change it out again? I want to clean the engine and have seen many videos and they all say different things, someone let me know any knowledge or recommendations on how long i should run it for, was originally thinking 1500miles but i run a glasspack muffler on stock exhaust and it runs very rich in result so I think the carbon build up is heavy and don't want to hurt the motor. Feedback in any way is appreciated just wanted 2nd opinions
Old May 17, 2025 | 10:21 PM
Never used the product.
Most Saturn folks use Seafoam on the S cars.
How much oil does it burn per 3k miles?
What does the Valvoline product claim to do?
Old May 18, 2025 | 08:14 AM
grcauto8453's Avatar
If you use a chemical treatment to clean the engine you'll likely live to regret it. Just keep the oil changed regular.
Old May 18, 2025 | 08:25 AM
I've been using it in both of my Kias for over 20,000 miles now. The 2016 Soul my son drives has the 2.0 GDI engine (which I hate) and was using a quart every 800 to 1,000 miles. It's now down to a quart every 5,000 miles. It currently has a tad over 109,000 miles on it. I also run it in my 2017 Kia Forte with a 2.0 MPI engine and it uses about a pint between 5,000 mile oil changes. It currently has 177,203 miles on it. I will keep using it as long as I can purchase it. The GDI is a terrible design for an engine as the valves don't get a wash by the injector spray like the MPI engines do and thusly develop carbon deposits on the valves. I'm hoping that by just doing a valve cleaning every 30,000 miles and changing the oil every 5,000 miles will make this Soul last at least until he gets it paid off. Time will tell the tale. I also use genuine KIA oil filters. I was running Mobil1 and using Mobil1 filters on both cars, but swapped both to the Valvoline Restore and Protect 5W-30 at the same time over 20,000 miles ago. Give or take a hundred or so miles. I'm happy with it and plan on just staying with it from now on.
Old Jun 5, 2025 | 09:59 PM
Eli Smith's Avatar
Heard that my oil didn't turn black till after 500 miles instead of sitting 100 after an oil change but it burns it still but a little less but I'm pretty sure piston rings are goings bad and she could use a rebuild but u appreciate the knowledge and experience, it definitely helps i think I want to change it again already at 600 miles currently but I want to keep only full synthetic in in from now on I've always put regular motor oil in it for the longest and I hope it helps with oil burning.
Old Jun 6, 2025 | 07:40 AM
Do at least 3 oil and filter changes at whatever mileage intervals you're comfortable (I'd suggest 3,000 to 5,000) and see if the oil consumption has decreased. Make sure you use a good filter too, not some $3.00 junk you get at a discount store. I'm pretty sure you'll like what the results are, but maybe it's just because I've always taken care of my cars. Oil to a car is like water to people. It's life!!
NMRAmustangracer
May 26, 2014 02:19 PM
Willthrox
Oct 13, 2010 09:04 PM
Rogger
Sep 10, 2008 05:19 PM
MINICooperS
Apr 22, 2008 08:59 AM
Bobcat698
Mar 9, 2007 08:00 PM
