so much for getting back on track.
Old Jul 20, 2014 | 11:19 PM
goaliemo's Avatar
Default so much for getting back on track.
glad my vacation starts tomorrow. go to get my sister from work tonight,
and I hear this ticking sound I suppose. I don't even know how to search for this (yes, I know the search engine but Ion ticking noise probably wont get me far)
Here is a sound clip, I hope one of you guys can helps so I can fix this this week.
https://www.youtube.com/watch?v=-61w...ature=youtu.be
Old Jul 21, 2014 | 07:54 AM
You got oil in the car, Billy? That sure sounds a lot like valve noise to me.
Old Jul 21, 2014 | 08:39 AM
goaliemo's Avatar
yes I do. Literally just changed the oil. I know I have an oil leak somewhere, but its like a quart every 2k miles.
Old Jul 21, 2014 | 05:53 PM
goaliemo's Avatar
someone else said it might be a stuck pulley? Gonna look into that too.
Old Jul 22, 2014 | 07:51 AM
Spray some carb cleaner or WD-40 or something around your intake manifold. It almost sounds like a leak there. Of course, that will only change the idle if it's an intake leak. If it's an exhaust leak, it won't make a bit of difference. It doesn't sound much like a pulley to me, but I'm not a mechanic. I've just been working on my own cars for over 40 years.
Old Jul 22, 2014 | 02:20 PM
goaliemo's Avatar
I am going to try that too. Im just trying to get a few different opinions on it so I at least have an idea. I don't want to just start unbolting everything and be screwed in the long run.
Old Jul 22, 2014 | 04:30 PM
goaliemo's Avatar
so, I changed the spark plugs, again. and the noise seemed to have stopped. im slightly confused. im about to take the car out again, and I should know for sure.
Old Jul 22, 2014 | 05:37 PM
goaliemo's Avatar
nope. didn't help. so gonna run the pully cleaner through. and clean the intake manifold. see if that helps.
Old Jul 22, 2014 | 05:56 PM
Do you hear any kind of noise is you manually rotate the engine, man? I know you can't turn a lot of rpms this way, but if you have a bad pulley or bearing perhaps it would squeak or scrape that way and you can narrow down its location.
Old Jul 22, 2014 | 06:41 PM
goaliemo's Avatar
I have to try that.
I love this car to death, but when I have an issue, its major. There is never an in between, yuh know?
