Just an idea
Old Jan 17, 2019 | 11:34 PM
Gain power.
Burn up Valves
Bummer
Old Jan 18, 2019 | 06:26 PM
19bonestock88's Avatar
From what I understand the S cars run like 10:1 rich or something and N/A engines make best power between 12.5:1 and 13:1 AFR... danger only usually exists when approaching 14:1 under heavy load, though richer is usually safer. Situations can arise where due to intake air temp or coolant temp the optimum AFR for best power becomes dangerous with the stock timing map, but the resultant damage is usually the piston, not the exhaust valve
Old Jan 20, 2019 | 06:11 AM
S cars are in the 9.x:1 range, and it is my understanding that if you lean it out too much, combustion temperature is too high and eventually melts the exhaust valves
Old Jan 22, 2019 | 03:00 AM
9.x:1 air fuel ratio? Wow, that is pig rich lol...
or or were you referencing the static compression ratio?
Old Jan 22, 2019 | 06:46 AM
Eehhnnnnhhh (buzzer)
I was thinking compr ratio
So sorry
Old Jan 24, 2019 | 12:54 AM
I think most of the S cars were 9.5:1, though with some creative swapping of parts you can arrive at something like 10.2:1 and still technically be “stock”...
I think the combo is late rotating assembly with early flat faced valves that gives high compression, but can’t remember 100% since I haven’t had an S car in forever, and if I got one as a project I’d likely be wanting to Ecotec swap it...
Old Jan 24, 2019 | 07:18 AM
Erik13's Avatar
Thank you guys for your input, and feed back I didnt know all that good information💯. Some one mentioned about boost??...., and well how can I boost my car?? What are the steps I could take??. Thank you..
teamsaturn125
Engine & Internal
Jan 7, 2019 08:05 AM
Merica
Dec 17, 2015 06:03 PM
Wesmonsta
Sep 30, 2012 04:41 AM
butthreeleftsdo
Feb 15, 2011 09:23 PM
Raab_himself
Jan 3, 2010 08:27 AM
