-   Engine & Internal (https://www.saturnforum.com/forum/engine-internal-16/)
-   -   Just an idea (https://www.saturnforum.com/forum/engine-internal-16/just-idea-11563/)
Erik13 Jan 6, 2019 11:58 PM
Just an idea
So I got a 93 Saturun sl 1.9L and I am trying to rally it out. I want to adjust the hole fuel system fuel tank, rail, regular ext, any ideas???.
derf Jan 7, 2019 04:00 AM
Most people use the old s cars for circle rack racing. The SL would need suspension mods and just doesn't have the power for the rally terrain IMHO.
What's the mileage and how much oil does it use?
Erik13 Jan 7, 2019 04:23 AM
Not to sure on the mileage only because the gauges are off and need new ones or check the wiring. The gass; for now I use it for work and back home witch is not to far.
Erik13 Jan 7, 2019 04:25 AM
I just did a oil change.
Erik13 Jan 7, 2019 04:26 AM
I seen many 4 bangers hooked up and I know my can too, just need to figure out the parts needed....
derf Jan 7, 2019 06:30 AM
Never said it couldn't be done.
J​​​​​ust offering up what I know and my perspective....
Most of what little aftermarket support there was for the s cars vanished 15 years ago
Erik13 Jan 7, 2019 06:42 AM
I understand bro. Sorry, but yes it's going to be a mission for this build💯
derf Jan 7, 2019 09:55 AM
Full speed ahead, Cap'n.
Can you do your own fabrication?
Maybe hang out at a few circle track races if for no other reason than to find out where these folks are getting parts or which parts they are modding from other vehicles to reach their objectives. It's of course not the same setup you'd use for a rally car, but it's a starting point.
Must be a way to get the DOHC rear anti sway bar in there.
As you've already figured out, my 97 SC2 w/263k and 95 SC2 w 236k are both bone stock.
02 LW300 Jan 7, 2019 09:19 PM
Be wary of too many smog mods, I think I see California plates on your car. The C.A.R.B. does not have a sense of humor.
19bonestock88 Jan 17, 2019 05:34 PM
Just a thought, but what mods do you have that make you think you need to adjust the fuel system? If the engine is stock and the cams are stock and you don’t have boost, chances are that doesn’t need a fuel system upgrade. The S series cars actually run pretty rich going wide open and people oftentimes will lean the mixture to gain power
